Cause: 480 Temporarily Unavailable/INVITE from
Discussion in '3CX Phone System - General' started by Sepp, Jul 17, 2013.
  1. Sepp
    Jul 7, 2008
    21
    The internal phone system works fine, but all my outgoing calls return the following
    it used to work and I checked my VoIP lines are properly registered....
    Your help is very much appreciated
    Sepp
    11,095
    327
    Is this happening on all numbers dialled?
    It may be worth speaking to your provider if it used to work and you have confirmed that you are sending the correct digits.
  3. Sepp
    Jul 7, 2008
    21
    Yep all numbers
  4. StefanW
    Jun 2, 2009
    1,222
    93
    Important is the IP after this line: INVITE from XXX.XXX.XXX.XXX
    If this is the IP of your provider, then give him a call. Is it a pstn gateway then check your pstn connection is it the pbx ip there, then you need to dig further into the logs...
  5. Sepp
    Jul 7, 2008
    21
    Thank you very much will do
    Sepp
