CDR Cost a penny a second?
Discussion in '3CX Phone System - General' started by John_in_NC, Apr 21, 2010.
  1. John_in_NC
    Apr 21, 2010
    15
    Hey guys, I am a Trixbox/Asterisk converted user. Very impressed so far as to the ease in setup on the 3CX system.
    Was hoping someone could help me tweak a setting. Not sure of the file structure so a breakdown of any INI's or other settings I can tweak would be a plus.
    I have a guest that uses my phone system so would like to use the "Cost" field in the CDR report. But I am not so sure I understand where it get's its calculations. I am looking at one call for example; ring time 00:00:03, talk 00:01:02, Cost shows up at 1.04. Is that $1.04?
    Do I understand that this is one penny a second?
    Can someone please explain where I can tweak this?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Hi there,
    Always nice to hear that we managed to convert an Asterisk user to 3CX.
    To answer your question, what you are looking for is in the 3CX Management Console > View > Billing Information.
    1.04 is the cost for your 1:02Minute call.
    By Default 3CX's billing information has all of it's values set to 1.0 per minute.
  3. John_in_NC
    Apr 21, 2010
    15
    Thanks for the quick reply.
    I know some places and regions cost more but for the time being is there a way I can simply change it to cost .02 per minute?
  4. LeonidasG
    Nov 19, 2008
    1,406
    81
    Yes of course, as i said you can go in the Management Console > View > Billing Information and change the cost for the region you like.
    You can change those values, they are not there just for show :p
    You can even add your own regions / prefixes if you go down to the end of the list.
  5. John_in_NC
    Apr 21, 2010
    15
    Okay great!! Thanks!
  6. haikton
    Dec 16, 2013
    Hi.
    I've an issue with "Cost" field. Cost shows 00:00 when "Talking" shows(to mobile network or fixed line) 00:04 minutesor other not 0 minutes value within report. So when I calculate the cost it's bring a huge difference.
    What could be the issue, please help I need it to create invoice.
    Thanks in advance.
    Hyak
