CDR Ouput
Discussion in 'CRM / Helpdesk / App Integration' started by jdb, Oct 27, 2009.
  1. jdb
    jdb
    Oct 27, 2009
    Is CDR\SMDR output available and if so what is the format?
    Also how can this information be collected by a third party application?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Call detail records are generated by 3CX just like for regular calls. You can query them using the 3CX Call Reporter tool.
    Also, if you need more information about user behavior in the VAD callflow (for example, options selected, etc.), you can use a File Management component or Database Access component to write call records to a file or database by yourself on call disconnection. That way you can integrate with any other system you need.
  3. jdb
    jdb
    Oct 27, 2009
    Thanks for response
    Just to clarify - we are the 3rd party developer.
    I need to know how we would be able to get access to CDRs - as an example - would our customer need to configure CDRS to be output to a file that we could then collect?
    Also I need to know what format they are in, eg. fields, field descriptions etc, as we would need to translate these CDRs for use in our own software.
  4. VAD_Support
    Aug 6, 2009
    690
    Call detail records generated by 3CX are in the PostgreSQL database, in the table "calldetails". You can explore it in your installation using a PostgreSQL client like this: http://sqlmanager.net/products/postgresql/manager/
    In that table you have information related to the call, but there is no information about what the user did into the callflow. If you need that information, you will need to generate call records in the VAD callflow using a File Management component or a Database Access component, so you can store them where you need, and with the data and format you need.
  5. jdb
    jdb
    Oct 27, 2009
    OK, thanks for that.
    We dont actually have an installation so I guess this is something the customer would have to do in order to generate CDRs
  6. VAD_Support
    Aug 6, 2009
    690
    Yes, your customer could see if the information generated is what they need. In that case just read CDRs from the database, otherwise you will have to add the required information using components in the VAD callflow.
  7. stefmar84
    Feb 27, 2009
    6
    Sorry, but i don't access on postgresql with pgamin to read the table called "calldetails".
    witch parameter i need to do that?
    thanks for all.
    Stefano Marconi
  8. VAD_Support
    Aug 6, 2009
    690
    Hi Stefano,
    Are you having problems connecting to the 3CX database? What are you trying to do?
  9. stefmar84
    Feb 27, 2009
    6
    I had developed an application for 3cx 7.1 that read the databsae of pbx (with ODBC) and copy data in my MsSql server for make particulary call statistcs and reports.
    I had accessed with this parameter on pgadmin:
    server: localhost
    port: 5480
    db:phonesystem
    username:logsreader
    password:logsreader
    when I update to V8 I can't access to db with the same parameter.
  10. VAD_Support
    Aug 6, 2009
    690
    Well, the database username and password may have been changed.
    Take a look at your 3CXPhoneSystem.ini file. The file is under C:\Program Files\3CX PhoneSystem\Bin. In that file you have different database usernames and passwords, for different purposes (logsreader, configuration, etc.).
  11. stefmar84
    Feb 27, 2009
    6
    in my file 3CXPhoneSystem.ini i have this settings:
    [CallReports]
    USERNAME=logsreader
    DATABASE=phonesystem
    PORT=5480
    DRIVER=PostgreSQL Unicode
    SERVER=localhost
    ReadOnly=1
    PASSWORD=Bq4=5Y_j/njkjh3kj{2+Hc
    the password is encripted. how I can use that?
  12. stefmar84
    Feb 27, 2009
    6
    Sorry,
    i tryed the password and i enter.
    thanks for all
    STefano Marconi
  13. VAD_Support
    Aug 6, 2009
    690
    Yes, the password is not encrypted, it is generated with a strong password generation tool, but not encrypted.
  14. Luis Santos
    Jul 17, 2017
    18
    ive created a tool, passive socket server that would collect all of the smdr data and output this to a splite file.
    further all of the reporting can be achieved with microsoft power bi
    PM me for further information or help with the setup
  15. asmith3006
    Mar 5, 2014
    94
    5
    FWIW I wouldn't access the database. You can have the CDR records outputted in a number of ways (push TCP, Pull TCP, file etc.) and then get the data from there. We made a very single Pull TCP connector which just get the strings, splits it and then passes it to another DB for us to interrogate at our will. Querying the main DB for the phone system is just an unnecessary strain which could cause issues in the future.
  16. Fresh Calendar
    Sep 30, 2017
    Take a look at your 3CXPhoneSystem.ini file. The file is under C:\Program Files\3CX PhoneSystem\Bin. In that file you have different database usernames and passwords, for different november 2017 calendar purposes (logsreader, configuration, etc.).
