CDR Output
Discussion in '3CX Phone System - General' started by MikeMelga, Jan 21, 2014.
  1. MikeMelga
    Mar 15, 2011
    77
    Hi.
    Is someone using the CDR output of 3CX?
    I am trying (without success) to make a socket connection to my application.
    I've activated CDR output in the advanced section and set it to output on a single call via socket. Still haven't managed to get any output.
    Does anyone have any experience with the CDR output? Any examples to share?
    Thanks.
    Regards,
    Mike
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Did you also modify the templates for the sockets? Hover your cursor over the question mark for the cdr options (settings, advanced cdr) and the system will show where the templates are located.
    Also, from the main search bar at the top of any of the 3CX webpages, simply type in CDR and look at the results. You will see some examples of its use.
  3. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    930
    150
    @MikeMelga
    Outside of 3CX, I would turn off any firewalls you may have on both ends until you confirm that it is working. 3CX makes any necessary Windows Firewall modifications for regular call flow, but I don't know about CDR output to socket.
  4. MikeMelga
    Mar 15, 2011
    77
    Ok....I've managed to get some output.
    It seems the port I've set in the template was already in use. I've changed the port and started getting output.
    Still don't know if this will serve it's purpose but....I guess I'll find out soon :)
    Thanks for your help!
    Regards,
    Mike
  5. MikeMelga
    Mar 15, 2011
    77
    So... I've been testing CDR output.
    It doesn't seem to pass the kind of information I would need.
    For example: the extension and group only reflect the initial extension and group. If you transfer the call to another extension... its always the first extension that shows up. Seems to be impossible to track the whole call.
    I would need to know in which extension the call has ended. Is this possible?
  6. lneblett
    Sep 7, 2010
    2,083
    61
    My guess is that you can get what you need, but have to modify the templates accordingly. The CDR is generally used as a feed for external billing systems. You might try the following:
    http://www.callaccounting.ws/
    They have a 14 day trial and interface with 3CX (look at the faq for details) and if not mistaken, this is the app that 3CX uses for their testing. Otherwise, you may have to outline your exact requirements and contract with 3CX or an outside 3rd party house to get what you need.
  7. MikeMelga
    Mar 15, 2011
    77
    lneblett,
    Thanks for the reply.
    Are you saying that 3CX can output more parameters than those included in the xml templates?
    I've taken a look at the Call Accounting app and nothing there indicates that they use anything other than the parameters on the template :(
    Unless there are indeed more parameters being output... I'm at a dead end.
  8. lneblett
    Sep 7, 2010
    2,083
    61
    http://www.3cx.com/manual/3CXHotelModuleManual.pdf
    Nope, not saying that more is available as a fact, just surmising. take a look at the above link.....it might also prove insightful....look at smdr as well.
