CDR Outputs Same Time Zone as PBX
Discussion in 'Ideas' started by Frick, Aug 4, 2017.
  1. Frick
    Jun 2, 2017
    9
    5
    Currently the CDR records are time stamped using UTC, regardless of what the PBX timezone is set to.
    I would like an option for the CDR records to be output using the same time stamps that the PBX is configured to use.
