CDR Record - Change file location
Discussion in '3CX Phone System - General' started by kmedri, Oct 29, 2014.
  1. kmedri
    Oct 29, 2014
    8
    I am trying to save the cdr record to a folder on a different pc on the network to where 3cx is hosted.
    I have amended the xml file and set; Folder="\\PCC-1598666\Calls\"
    however it looks like the file path is being prefixed with C:\ProgramData
    Is there a way to prevent this from happenning
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    You cannot change the file location to somewhere outside the ProgramData folder, but you do have other options:
    1) You can change the CDR Output method from file to socket, and the 3CX Phone System will send the information over the network to the specified IP and socket. Instruction on how to do this can be found here:
    http://www.3cx.com/blog/docs/cdr-call-data-records/
    2) If you want to keep things simple and just work with files, you could just write a script that copies the file from the default location every X minutes through the Windows Task Scheduler feature.
  3. kmedri
    Oct 29, 2014
    8
    Thank you Nick.
    I added a task in the schedular to move the files across to may other software using:
    cmd /c move /Y C:\ProgramData\3CX\Data\Logs\cdrmulti\*.* \\mynetworklocation\Calls
    Set to do this every five minutes
    Works great
