CDR Reports Linux
Discussion in '3CX Phone System - General' started by neville, Aug 7, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    226
    42
    I am trying to generate cdr reports. I enabled it, select the fields to output and hit OK. When I check /var/lib/3cxpbx/Instance1/Data/Logs/CDRLogs, there is nothing there. Is there something else I need to do to enable this feature?
    Chuck
  2. neville
    neville New Member
    Apr 23, 2012
    226
    42
    This started working finally. It took a while for it to populate.
