CDR to include original diverted number
Discussion in '3CX Phone System - General' started by LiveRock, Jan 20, 2015.
  1. LiveRock
    Jan 19, 2015
    17
    I wonder if this is possible.
    Caller A calls B's mobile number on normal GSM network.
    B's mobile is set to 'DIVERT WHEN BUSY' and caller A gets diverted to a VOIP DID and using 3CX.
    At 3CX, would I be able to:
    1. record a voicemail
    2. captures BOTH A's and B's caller ID
    Is this scenarios possible?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    1) leave a voicemail,for any extension that has it enabled
    2) not mobile->3cx unless the gsm adds some header info. But 3cx isn't likely to read it for you. You would have to capture it in wire shark.
  3. LiveRock
    Jan 19, 2015
    17
    Thank you Craigreilly.
    Will check on wireshark for this.
