Cellip and 3cx
Discussion in '3CX Phone System - General' started by ansu2723, Dec 9, 2008.
  1. ansu2723
    Nov 23, 2008
    29
    My incoming calls from cellip disconects after 32 seconds.
    This is the log from 3cx:
    Hej,
    Vi har valt att använda Cellip som leverantör av IP-telefonin in till växeln. Dock kopplas samtalet ner efter 32 sekunder när någon ringer in.
    Skickar med logg.
    Har inte fått några fler svar från 3cx.
    08:16:55.328|.\CallLeg.cpp(122)|Log5||CallLeg::eek:nNewCall:[CM500002]: Info on incoming INVITE:
    INVITE sip:46855116173@212.214.67.18:5060;rinstance=632748d54252b7e1 SIP/2.0
    Via: SIP/2.0/UDP 62.80.200.53;branch=z9hG4bKd96a.94690a4edf255d3336f4898fdefde5a4.0
    Via: SIP/2.0/UDP 62.80.200.53:5061;branch=z9hG4bKa3988e6c0af3c6feaa07ba5523c071bc;rport=5061
    Max-Forwards: 16
    Record-Route: <sip:62.80.200.53;ftag=89cb10a5745024daef138d437e864181;lr>
    Contact: "Anonymous"<sip:62.80.200.53:5061>
    To: <sip:46855116173@62.80.200.53>
    From: <sip:0704153200@62.80.200.53>;tag=89cb10a5745024daef138d437e864181
    Call-ID: 35D7BC92-C4F811DD-9625E066-9C41421C@62.80.200.60
    CSeq: 200 INVITE
    Expires: 300
    User-Agent: Sippy
    Content-Length: 0
    cisco-GUID: 873290681-3304591837-2879651855-4157623384
    h323-conf-id: 873290681-3304591837-2879651855-4157623384
    <br>
    08:16:55.359|.\Line.cpp(286)|Log5||LineCfg::getInboundTarget:Looking for inbound target: called=46855116173; caller=0704153200<br>
    08:16:55.375|.\Line.cpp(311)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound office hours rule for 10004 forwards to DN:86<br>
    08:16:55.390|.\CallCtrl.cpp(135)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(1): Incoming call from 0704153200@(Ln.10004@Cellip) to <sip:86@192.168.99.50:5060><br>
    08:16:55.406|.\Line.cpp(1110)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Cellip] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] Transport: [sip:192.168.99.50:5060]<br>
    08:16:55.406|.\CallLeg.cpp(737)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:1.1<br>
    08:16:55.406|.\CallCtrl.cpp(295)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:86@192.168.99.50:5060><br>
    08:16:55.406|.\SLServer.cpp(766)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:1.1:Offer received. RTP connection: 62.80.200.53:39310(39311)<br>
    08:16:55.406|.\CallCtrl.cpp(404)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(1): Calling: Ext:Ext.86@[Dev:sip:86@127.0.0.1:40600;rinstance=3b8cb3b4efa2825b]<br>
    08:16:55.406|.\SLServer.cpp(766)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210004] C:1.2:Offer provided. Connection(proxy mode): 127.0.0.1:7000(7001)<br>
    08:16:55.984|.\CallCtrl.cpp(212)|Log3||CallCtrl::eek:nAnsweredCall:[CM503002]: Call(1): Alerting sip:86@127.0.0.1:40600;rinstance=3b8cb3b4efa2825b<br>
    08:16:55.984|.\CallLeg.cpp(737)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:1.2<br>
    08:16:56.000|.\Extension.cpp(922)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.86: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX Queue;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue] Transport: [sip:127.0.0.1:5060]<br>
    08:16:56.000|.\SLServer.cpp(766)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210001] C:1.2:Answer received. RTP connection: 127.0.0.1:40612(40613)<br>
    08:16:56.000|.\SLServer.cpp(766)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210005] C:1.1:Answer provided. Connection(proxy mode):192.168.99.50:9000(9001)<br>
    08:16:56.000|.\CallCtrl.cpp(524)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(1): Device joined: sip:62.80.200.53:5061<br>
    08:16:56.000|.\CallCtrl.cpp(524)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(1): Device joined: sip:86@127.0.0.1:40600;rinstance=3b8cb3b4efa2825b<br>
    08:16:56.093|.\CallLeg.cpp(122)|Log5||CallLeg::eek:nNewCall:[CM500002]: Info on incoming INVITE:
    INVITE sip:Q86@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-312a0549642f9473-1---d8754z-;rport=40600
    Max-Forwards: 70
    Contact: <sip:86@127.0.0.1:40600>
    To: <sip:Q86@127.0.0.1:5060>
    Call-ID: ODlhYzZmNDMxMmZjYjlkMTkzNWVmOGM2YzVhNTlkZGI.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Proxy-Authorization: Digest username="86",realm="3CXPhoneSystem",nonce="12873280616:db0860764294445d6dbfe0b675bb7b7e",uri="sip:Q86@127.0.0.1:5060",response="a1991e8c4348caa317c91c91991fe801",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX Queue
    Content-Length: 0
    <br>
    08:16:56.109|.\CallCtrl.cpp(135)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(2): Incoming call from Ext.86 to <sip:Q86@127.0.0.1:5060><br>
    08:16:56.109|.\Extension.cpp(922)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.86: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX Queue;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue] Transport: [sip:127.0.0.1:5060]<br>
    08:16:56.125|.\CallLeg.cpp(737)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:2.1<br>
    08:16:56.125|.\SLServer.cpp(766)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:2.1:Offer received. RTP connection: 127.0.0.1:40610(40611)<br>
    08:16:56.125|.\CallCtrl.cpp(295)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:Q86@127.0.0.1:5060><br>
    08:16:56.125|.\CallCtrl.cpp(404)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(2): Calling: Queue86:10Ext.10@[Dev:sip:10@192.168.99.114:1028;line=s3j43lr5]<br>
    08:16:56.140|.\SLServer.cpp(766)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:2.2:Offer provided. Connection(transcoding mode): 192.168.99.50:7004(7005)<br>
    08:16:56.140|.\CallCtrl.cpp(410)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503016]: Call(2): Target is not registered: Queue86:11Ext.11<br>
    08:16:56.484|.\CallCtrl.cpp(212)|Log3||CallCtrl::eek:nAnsweredCall:[CM503002]: Call(2): Alerting sip:10@192.168.99.114:1028;line=s3j43lr5<br>
    08:16:56.484|.\Extension.cpp(922)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.99.50:5060]<br>
    08:17:28.125|.\InviteADS.cpp(535)|Log2||InviteADS::eek:nAckNotReceived:[CM503020]: Call(1): ACK is not received<br>
    08:17:28.125|.\Call.cpp(760)|Log2||Call::Terminate:[CM503008]: Call(1): Call is terminated<br>
    08:17:28.859|.\Call.cpp(760)|Log2||Call::Terminate:[CM503008]: Call(2): Call is terminated<br>
    Anyone that can tell me what the problem is? I can see it is disconnecting but why?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    278
    This is a firewall configuration problem. Remember you need STATIC port forwarding.
