central phone book?
Discussion in '3CX Phone System - General' started by aftermarket, Jul 19, 2009.
  1. aftermarket
    May 13, 2009
    84
    does anyone know how i can get the phones (cisco 7940) to read from a central phone book within the 3cx voip server?
    thanks
  2. thenua
    Jun 5, 2009
    38
    Hi aftermarket,
    I suspect not.
    I use SPA942's (originally Linksys and now referred to as Cisco Small Business). In the case of the SPA942, I believe the central phone book can only be picked centrally via LDAP which is not the 3CX approach. So I have not managed to resolved this one for the SPA.
    Hopefully someone else can post more specifically for the 7940.
    Regards
    thenua
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Open SIPDefault.cnf and add the below at the bottom
    # Phone Book Directory
    directory_url: "http://192.168.1.64:5000/provisioning/cisco_phonebook.xml"
    change the IP address to match your 3CX server
  4. Sha1a
    May 18, 2011
    15
    Have you tested that with a CISCO 7945G? If not I will and can report.
  5. davidbenwell
    Apr 27, 2010
    704
    no, only tested with the 7940, but should work with the 794* Series
