Solved Certificate error with internal webclient
Discussion in '3CX Phone System - General' started by perfectcast, Dec 19, 2017.
  1. perfectcast
    Apr 27, 2016
    7
    When browsing to the webclient on my customer's internal network I get the following certificate error on edge and chrome
    "There’s a problem with this website’s security certificate"
    I can continue to the webclient login page and use all functionality
    When I look at the certificate details I can see a warning ! against the following key details
    Key usage & Key constraints
    If I browse to the webclient externally everything is fine.
    Has anyone else seen this?
    Appreciate your feedback on this as its disconcerting for the users
    cheers
    Neil.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Have you installed 3CX using internal FQDN or IP address ?
    Is FQDN resolving internally to the internal address of the PBX ?
    If not, use: http://<internal_address_of_PBX>:5000 to access the PBX.
  3. perfectcast
    Apr 27, 2016
    7
    3CX is running on an internal network
    The fqdn resolves to the public ip of the pbx so I'm trying to access the webclient on the internal network I'm using the internal server ip.
    accessing from remote locations via the fqdn works perfectly without error
    https://<internal_3CX_server_ip:5001/webclient
    as per the link in the welcome mail sent to user extension
    Neil.
  4. sip.bg
    Nov 7, 2016
    704
    220
    Certificate is linked with FQDN.
    If you are trying https at internal address, there is no valid certificate for it, cerificates don't work on addresses. Try DNS splitting, if you can, in order FQDN to resolve internal address of the PBX, when used internally, or use http and port 5000 instead of https and port 5001 on internal address.
  5. perfectcast
    Apr 27, 2016
    7
    thats perfect thanks for your help, using 5000 has resolved the issue
    have a good christmas
    cheers
    Neil.
