Solved Certificate problem
Discussion in '3CX Phone System - General' started by John Brown, Dec 24, 2017.
  1. John Brown
    Dec 24, 2017
    Im sorry if this has already been answered but I searched and came up empty. I installed 3cx with pbxexpress on my google cloud vm instance and I am having a problem logging into it due to the certificate issue. I read over the info you have available and downloaded the generator and created a key and csr for it. when I try to install the certificate in my browser, however, it says that it is an unknown file type. any ideas?
    I realize the certificate files I created have to be uploaded to my cloud 3cx but I cant get to that point if they wont install in my browser.
  2. John Brown
    Dec 24, 2017
    I was able to figure out what it was. You have to check "allow" http/https to connect, in Google Cloud settings.
    accentlogic likes this.
  3. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hi John Brown,
    Glad to see your issue was resolved an thank you for sharing the solution.
