CFD beta - Project Variables
Discussion in 'Call Flow Designer' started by millsey, May 27, 2017.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    The Variable Collection Editor no longer evaluates variables. For example I have a project which sets variables matching session.dnis, session.ani and session.callid - this works fine for the VAD for version 14.5 but does not work for the CFD beta. I now get errors during build:
    Error compiling source code to .NET library (118.57) error CS0103 The name "session" does nto exist int eh current context.
    I change one of the three variables values to 0 and the number of errors reduced from 3 to 2.
    Regards
    Millsey
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hi @millsey,
    Thanks for your feedback. This seema to be a bug, we'll check and fix it. However, it doesn't seem to be necessary that you assign the session variables to another project variable, as session variables will be available thru the entire call flow and components.
    Anyway if you need to assign them, you can add a Variable Assignment component at the beginning of your callflow, and it will work.
    Kind regards.
