CFD configuration
Discussion in 'Call Flow Designer' started by Angelo Luongo, Dec 6, 2018 at 3:44 PM.
  1. Angelo Luongo
    Thursday
    The customer, asks me how he can select within the CFD the "transfer" to multiple extensions, seeing from the manual is written to insert more internal separated by comma, but does not work, he would not use the ringtone group because he can not make send an email if the call is not answered, I ask if it can be sent by CFD.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,596
    125
    The Transfer component in a CFD app will transfer the active call connected to the CFD app, to the destination you specify. This is a single number, you can't transfer the call to multiple numbers. You can use a Ring Group instead, and then all the extensions will ring. You can configure the "Destination if no answer" for the Ring Group, and transfer the call to a voicemail or a different CFD app to send an email...
  3. Angelo Luongo
    Thursday
    how can I create a CFD app that sends an email to the missed answer?
  4. edossantos
    Jun 27, 2007
    1,596
    125
    You create a CFD that sends an email when it receives the call. Then, you configure the Ring Group to send the call to your CFD app if nobody answers after N seconds.
  5. Angelo Luongo
    Thursday
    but how can I run a CFD app in a RingGroup inside 3cx Console , in the "Destination in case of no response" option ?
  6. edossantos
    Jun 27, 2007
    1,596
    125
    Exactly!
