CFD-MUSIC ON HOLD- Previous music correction
Discussion in 'Ideas' started by Brandan Hermo, Mar 7, 2018.
  1. Brandan Hermo
    Jul 10, 2017
    39
    7
    When CFD is used, the music on hold is listened to a fraction of the time and is behavior that can not be modified and is annoying for the clients.
