CFD Transfer to Voicemail
Discussion in 'Call Flow Designer' started by dredd0606, Mar 2, 2018.
  1. dredd0606
    Feb 14, 2018
    40
    10
    Is there a way to transfer to an extensions voicemail in CFD? I know *4EXT will transfer directly to VM, but the * is being rejected in the transfer component when I try to build.
    Thanks in advance,
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,078
    76
    Hello @dredd0606,
    You need to use quotes, for example:
    "*4100"
    Kind regards .
  3. dredd0606
    Feb 14, 2018
    40
    10
    Thank you very much edossantos!!!
