Change 3CX Status to "away" wen lock the Workstation
Discussion in 'Ideas' started by Tobias Pieper, Dec 31, 2017.
Change 3CX Status to "away" wen lock the Workstation 4.7 5 19votes
4.7/5, 19 votes
  1. Tobias Pieper
    Dec 31, 2017
    6
    Good evening,
    when the 3CX Windows Phone Client is running in the Presence status "Online" an the Workstation is locked after a time or then press Strg-Alt-Entf.
    My Wish: Wen the Workstation is locked, switch the Presence Status "automatic" to "away".
    Actually this is a normal feature in the field of UC.
    For Example: Skype or Skype for Business works this Feature at all time! ;)
    Thanks for your respons.
    Please Vote/Rate for my Post above my Post
    #1 Tobias Pieper, Dec 31, 2017
  2. michielpeeters
    Nov 17, 2008
    20
    5
    I wrote this batch file and made a shortcut on the desktop.
    It will change status to Away.
    Lock the computer
    When the computer is unlocked, you press enter to change status to Available.
    Code:
    @echo Off
    cls
    Echo Your computer is being locked.
    "C:\ProgramData\3CXPhone for Windows\PhoneApp\"3CXclicktocall.exe *31"
    rundll32.exe user32.dll, LockWorkStation
    cls
    echo Welcome back, press any key to change your status to Available.
    Pause
    "C:\ProgramData\3CXPhone for Windows\PhoneApp\"3CXclicktocall.exe *30"
    exit
    Paul Omans and info@matic-tec.de like this.
  3. info@matic-tec.de
    Mar 25, 2008
    36
    22
    Very nice workaround, but I also think this should be an option in 3CX Phone for Windows.
  4. 3CXDude
    3CXDude New Member
    Oct 1, 2015
    111
    30
    This might help
  5. info@matic-tec.de
    Mar 25, 2008
    36
    22
    But change status to "Away" on lock should be an additional feature.
  6. michielpeeters
    Nov 17, 2008
    20
    5
    Of course you can also use Scheduled tasks to execute 3CXclicktocall.exe *31 / *30 and begin the task on "on workstation lock / unlock".
    Lev, accentlogic and Paul Omans like this.
  7. Lev
    Lev New Member
    Sep 19, 2015
    122
    18
    Yo!
    It is possible to have "lock computer" and "unlock computer" to be used as triggers for tasks in the windows task scheduler.
    Just tried it out and i can tell "IT'S ALIVE!" :)
  8. DavidWebb
    Jul 22, 2016
    18
    I like the task scheduler option, except for one instance. If someone is set to do not disturb, or lunch or something like that, when they lock their computer it shouldn't switch to away, and when they come back it shouldn't auto switch to available. Maybe they brought their lunch to their desk and are still eating with their computer unlocked.
    I would still like to have 3CX add an option so that it will only set it to Away if they were Available when they locked their workstation, and only set it to Available when they come back if it was set to Away from being locked.
