Change Cassini Port?
Discussion in '3CX Phone System - General' started by cknott2243, Jul 22, 2010.
  1. cknott2243
    Jul 6, 2010
    49
    Hi all,
    I am new to 3CX and thus far am very happy with it. There are a few small things I am trying to work through but all in all it has been very easy to setup and administer. The one thing that really bugs me is the Cassini port, can this be changed? It is a pain to try and remember to use port 5481. I am not great with IIS so decided to go the easier route and use Cassini.
    So my question is, can the port for Cassini be changed? I am running version 8.
    Thanks for any replies.
  2. carolinainnovative
    May 4, 2009
    369
    5
    If you're actually going to use Cassini for production, consider installing Version 9. The current Release Candidate is likely to be made the "gold" release here very shortly... Version 9 includes Abyss instead of Cassini - which is MUCH more stable and designed for production use. 3CX support has done a lot of load testing for Abyss to verify its stability.
    See here for how to change the port in Abyss:
    http://www.3cx.com/forums/ivr-error-when-changing-abyss-web-management-port-15526.html#p79432
