Change default backup location?
Discussion in '3CX Phone System - General' started by Sopock, Jul 29, 2016.
  1. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Hi!
    I think there should be some warning for default backup location
    (until uninstall) :shock:
  2. andreaschr
    Oct 26, 2015
    91
    6
