Change Default Local IP in 3CX?
Discussion in '3CX Phone System - General' started by jas07, Mar 26, 2009.
  1. jas07
    Mar 23, 2009
    28
    Hi Guys,
    Ive got a problem in that the machine that has 3CX on has got 2 Network adaptors, and for some reason 3CX is picking up the Default Local IP as the wrong adaptor, Ive tried setting the adaptor i dont want it to use and calling it ZZZZZZ and leaving the one i want it to use set to Local Area Connection but its still picking up the wrong one.
    In Settings > Network > Stun Tab ive set the IP to the correct adaptor but its still picking up the wrong one.
    The reason i need this is that its using the wrong adaptor to try and register the VOIP Provider and its failing as there is no net on that adaptor. Incoming connections are fine its just the outgoing.
    Any Ideas?
    Jas
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    In the Control Panel > Network Connection > Advanced > Advanced settings, try to move the NIC you wish the server to use to the top of the list.
    Then reboot the machine and advise the outcome.
  3. jas07
    Mar 23, 2009
    28
    Ive not got that, in the Control Panel ive got:
    Settings > Network OR Advanced, Neither have an "Advanced Settings" however. And Certainly none show the NIC?
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Once you are in the Network Connections window from Control Panel you go to the menu's across the top of the window.
    There should be File, Edit, View, Favourites, Tools, Advanced, Help
    In XP under the Advanced menu there is "Advanced Settings" which is where you can move the order of the network adapters.
  5. jas07
    Mar 23, 2009
    28
    Sorry i was in the 3CX control panel looking there.
    LAC is top which is the correct one and the one i dont want it to use is last.
  6. William400
    Aug 21, 2006
    1,005
    Can you please paste a 'route print' output in reply to this post.
  7. jas07
    Mar 23, 2009
    28
    For some reason it does actually appear to be working correctly now, although ive changed nothing at all the last few reboots have been ok.
    Here is the route print as requested though
    Interface List
    16 ...00 0c 41 e1 f7 e5 ...... Bluetooth Device (Personal Area Network)
    8 ...00 1d 92 f4 30 b5 ...... Realtek RTL8168C(P)/8111C(P) Family PCI-E G
    t Ethernet NIC (NDIS 6.0)
    17 ...7a 79 05 b1 d9 c1 ...... Hamachi Network Interface
    1 ........................... Software Loopback Interface 1
    20 ...00 00 00 00 00 00 00 e0 isatap.{7789E8ED-9C24-4716-A0EB-501130BE86C
    9 ...02 00 54 55 4e 01 ...... Teredo Tunneling Pseudo-Interface
    19 ...00 00 00 00 00 00 00 e0 isatap.{AE874E65-D5AA-4C90-B46D-EF8092EB32E
    21 ...00 00 00 00 00 00 00 e0 isatap.{B16457E4-8463-4E1F-B659-3B080742114
    22 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
    IPv4 Route Table
    Active Routes:
    Network Destination Netmask Gateway Interface Metric
    0.0.0.0 0.0.0.0 10.0.0.1 10.0.0.3 10
    5.0.0.0 255.0.0.0 On-link 5.177.217.193 9256
    5.177.217.193 255.255.255.255 On-link 5.177.217.193 9256
    5.255.255.255 255.255.255.255 On-link 5.177.217.193 9256
    10.0.0.0 255.255.255.0 On-link 10.0.0.3 266
    10.0.0.3 255.255.255.255 On-link 10.0.0.3 266
    10.0.0.255 255.255.255.255 On-link 10.0.0.3 266
    127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
    127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
    127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
    224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
    224.0.0.0 240.0.0.0 On-link 5.177.217.193 9256
    224.0.0.0 240.0.0.0 On-link 10.0.0.3 266
    255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
    255.255.255.255 255.255.255.255 On-link 5.177.217.193 9256
    255.255.255.255 255.255.255.255 On-link 10.0.0.3 266
    Persistent Routes:
    None
    IPv6 Route Table
    Active Routes:
    If Metric Network Destination Gateway
    22 1125 ::/0 2002:c058:6301::c058:6301
    1 306 ::1/128 On-link
    22 1025 2002::/16 On-link
    22 281 2002:5b1:d9c1::/128 On-link
    22 281 2002:5b1:d9c1::5b1:d9c1/128
    On-link
    17 20 2002:5b1:d9c1:11::/64 On-link
    17 276 2002:5b1:d9c1:11::/128 On-link
    17 276 2002:5b1:d9c1:11:5d56:1258:ce22:b188/128
    On-link
    17 276 2002:5b1:d9c1:11:c9d5:63f0:20a5:bb65/128
    On-link
    17 276 fe80::/64 On-link
    8 266 fe80::/64 On-link
    8 266 fe80::2ced:a735:b4af:ba06/128
    On-link
    17 276 fe80::c9d5:63f0:20a5:bb65/128
    On-link
    17 20 fec0:0:0:11::/64 On-link
    17 276 fec0:0:0:11::/128 On-link
    17 276 fec0::11:c9d5:63f0:20a5:bb65/128
    On-link
    1 306 ff00::/8 On-link
    17 276 ff00::/8 On-link
    8 266 ff00::/8 On-link
    Persistent Routes:
    None
    Many Thanks for your help
