change digital receptionist greeting
Discussion in '3CX Phone System - General' started by tlachau, Feb 25, 2016.
  1. tlachau
    Dec 3, 2015
    13
    Is it possible to change the digital receptionist greeting without having access to the management webpage?
    Ex: Our office would like to play a greeting in the event of bad weather to instruct employees to stay home... The office manager would like to call in from anyphone to record a greeting to the 'weather receptionist'. Overwriting of deleting any message that was already there.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    perhaps an extension for Employee Information Hotline.
    Just change the greeting.
  3. pat71
    Mar 17, 2016
    44
    How to do it using 3CX API?
  4. craigreilly
    Feb 1, 2012
    3,560
    301
    That was not your original question... and I do not use the API. Sorry I do not have any information for you.
  5. pat71
    Mar 17, 2016
    44
    Thank you
