Change DND over API
Discussion in 'Windows' started by 3cxMan, Sep 30, 2014.
  1. 3cxMan
    Sep 30, 2014
    I use the 3CXPhone for Windows Plugin API and I will set the state from DND in this api. At the moment I solved this with the makecall function on *61 and *60.
    Is it possible to do this direct and not over a call? And how I can do it?
    Thanks for your help.
    Greetings
    Manuel
