Change Extension Status (Available - Away) from the Phone
Discussion in '3CX Phone System - General' started by rnoguera, Nov 9, 2007.
  1. rnoguera
    Oct 25, 2007
    89
    Does anyone know wheter it is possible and how to do it?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    From the phone, it should be not supported.
  3. rnoguera
    Oct 25, 2007
    89
    I don't understand your answer.
    You mean "It is not supported NOW" or "It should not be supported IN THE FUTURE"?
    In my opinion, all the basic functions should be available from the phone. Voice Mail, and Presence are basic functions.
    Call Assistant is a great tool but it should not be necessary for the basic operation of the phone...
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    That's mean change Extension Status (Available - Away) from the Phone. The current version V4A is not supported. It may be supported in future.
    However, the extension status (Available - Away) can be changed by 3CX Call Assistant.
