Change extension status
Discussion in 'Ideas' started by chipware, Jan 26, 2017.
Change extension status 5 5 3votes
5/5, 3 votes
  1. chipware
    Aug 6, 2012
    please add a feature to change the extension status either with a dial code or from the 3CX softphone.
    Thanks in advance.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,334
    533
    This can already be done with both ways you are suggesting. You cal click on the available status on a 3CX client and select the status you want.
    Or you can dial *30 for available or *31 for away *32 for DND etc.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    I saw some discussion about this - not sure if from this OP or someone else. A Dial code to change the forwarding - not just set the forwarding status.
    ie:
    *36#109# will forward my calls to ext 109.
    *37# will remove the forwarding of my calls to ext 109.
    Yes - you can do this from the clients - but this is more convenient... and someone else can walk up to your phone and do it if you call in sick.
  4. Patrick Hogan10
    Nov 23, 2016
    27
    I agree with you Craigreilly, that does sound more convenient.
  5. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    You can also change your status through the voicemail system. Dial 9 for options.
    You could create a VAD extension that when dialed recognizes the extension making the call, and prompts you for the desired status and forwarding extension. "For Available, press 1, for Away, press 2", etc. It would then change the extension status and the pre-defined status forwarding rules would apply. Alternatively, it could say "to change the status of extension 103 Matthew Orr, press 1, to change the status of a different extension press 2"... then ask for the forwarding extension. Either way, the user is going to have to remember the VAD extension to dial, or the dial code to enter, unless you put the VAD extension on a BLF.
    You could also have a BLF toggle your extension between "Available" and "Away" using a single VAD extension. Press the BLF once and it updates your presence and plays a prompt "Your status has been changed to 'Away'". Press the same button a second time, and it would toggle it back "Your status has been changed to 'Available'".
    I know what you will ask next... can we change the light on the button based on presence. Maybe, but that would require some investigation. see www.VoIPTools.com
  6. craigreilly
    Feb 1, 2012
    3,545
    298
