change extension
Discussion in '3CX Phone System - General' started by vcopola, Sep 26, 2013.
  1. vcopola
    Jul 12, 2011
    10
    Hello
    there any way to change the extension number?
    I need to change the extensions of 1xx to 4xx and I do not want to create them hand one by one
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @vcopola
    Not possible in any supported way.
    If you have sufficient time, patience, and courage, you could create a backup file, mangle the XML file inside it, and try to restore the adjusted version. But you're on your own with this, really ;)
  3. vcopola
    Jul 12, 2011
    10
    OK, thank you very much.
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Would be ideal if the same mechanism which imports the csv could export the extension config to csv..
  5. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi Ian,
    The functionality exists for exporting the extension config to CSV. Click on the 'Extensions' node in the management console, select your extensions and click on 'Export Extension' from the top menu. you will then get your csv file. Please let us know if you have any further questions or inquiries.
    Best Regards
  6. vcopola
    Jul 12, 2011
    10
    Hello
    I have no option to export the extensions
    I attached capture
      File size:
      197.2 KB
      990
  7. AndreasP_3CX
    3CX Support
    Feb 15, 2013
    196
    Hi vcopola,
    lets say that you will have it in the near future then?:) Please bear with us even Rome wasn't built in a day:) If you have any further questions please let us know.
    Best Regards
  8. vcopola
    Jul 12, 2011
    10
    Ok ok, sorry, I had understood that it was done :)
  9. AndreasP_3CX
    3CX Support
    Feb 15, 2013
    196
    you are welcome, please let me know if you have any further questions.
    Best Regards
