change external IP after installation
max999
Hello!
Is it possible to change the external IP address, which must be entered on the first run of the 3CX System Management Server - Web Interface?
I changed my service provider!
I believe that you have to back-up, UN-install 3CX, re-install 3CX with the new IP, then re-apply the back-up.
There is an alternative, provided, in this post...
http://www.3cx.com/forums/can--call-via-voip-provider-17854.html
You may fix all appearances of your external address in Troubleshooting | Parameters.
Be careful.
However, in the roadmap for SP3 is expected the issue of changing external IP address to be solved.
OK, I made a backup - deleted the application - new install - restore - Everything OK
Getting Started - Admin
davide.luppi
Get 3CX - Absolutely Free!
3CX
