Change fax header of incoming fax (Ext 888)
Discussion in 'Ideas' started by J616, Dec 22, 2015.
  1. J616
    Dec 18, 2015
    To change it to company name vs 3CX Fax
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    Have you updated your template?
    Settings -> Email -> Email Template -> Fax
    I changed the logo if I recall to get rid of the "3CX FAX"
    I only see "Email sent by 3CX phone system www.3cx.com" at the bottom.
    The rest is customized.
  3. J616
    Dec 18, 2015
    No I'm referring to the header that's actually on the top of the fax pages. Also what the receiving fax machine uses as an identifier.
  4. craigreilly
    Feb 1, 2012
    3,569
    302
    Oh - the actual PDF file ?
