Solved Change FQDN afterwards
Discussion in '3CX Phone System - General' started by dustycr, Mar 8, 2017.
  1. dustycr
    Mar 7, 2017
    17
    Hello everybody,
    is there any way how i can change the fqdn afterwards ?
    For testing i used a dot 3cx Domain but now i want to use one of my own
    Do i have to reinstall the whole pbx or can i just create a full backup of the machine and restore it ?
    Thanks in advance.
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi Dustycr,
    In order to change the FQDN in v15 you will need to reinstall 3cx Phone system.
    As the FQDN will be bound to the PBX edition license key you will need to log in to the https://customer.3cx.com using the credentials located in the email you received with the PBX edition key and release the FQDN from the key in order to use the same FQDN again with the new key.
  3. dustycr
    Mar 7, 2017
    17
    Hi MRM,
    thanks your answer.
    Will all the settings etc. stay in the backup or do i have to create everything new ?
  4. MRM
    MRM
    Dec 21, 2016
    53
    Hi Dustycr,
    Create your backup & untick the FQDN & license box... as per pic below
    denko2k likes this.
  5. dustycr
    Mar 7, 2017
    17
    Thanks its working now ! :)
