Change fqdn ip
Discussion in '3CX Phone System - General' started by gignux, Sep 14, 2016.
  1. gignux
    Sep 14, 2016
    how we can change the ip adresss of FQDN mysite.3cx.eu?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Could you please specify on which version PBX are you on?
  3. user230971
    Sep 19, 2016
    I'm curious too, I registered myname.3cx.eu but I want to switch ISP.
    I'm using v15 of the PBX
    Thanks in advance.
    Regards,
    ESA
  4. YiannisH_3CX
    May 10, 2016
    7,783
    563
    to change your public IP in V15 navigate to settings >> Network and under the External IP Configuration change the value of your Ip address. Restart all services and if you have your own DNS server update your A record.
  5. 3cxBora
    Jun 17, 2015
    38
    How do I update the internal LAN IP address? Do I need to run sudo /usr/sbin/3CXWizard -1-cleanup
  6. YiannisH_3CX
    May 10, 2016
    7,783
    563
    When the local IP address of the PBX changes you will need to perform a backup without including license and FQDN, un-install using apt-get --purge remove 3cxpbx and reinstall using your backup.
