Change FQDNs in 3CX version 14 SP2
Discussion in '3CX Phone System - General' started by fonewiz, Feb 12, 2016.
  1. fonewiz
    May 13, 2015
    44
    I just upgraded a customer from 12 to version 14 SP2.
    During install I chose the separate local and external FQDN.
    I need to change the local FQDN in 3CX, then re-provision 3CX Clients.
    How can I do this? I searched Trouble Shooting >> Parameters for the internal FQDN and found a bunch of entries, do I just change them in there and I am good?
    I will also need to change the external FQDN once I get a second external IP address setup for this customer but that is secondary at the moment, the internal not being correct has broken their 3CX Client app completely.
    Thanks..
  2. 12494
    12494 Member
    Apr 16, 2010
    291
    25
    Do a backup, uninstall, then reinstall - answer the question the new way, restore.
    Allen
