Change from 24 hr time??
Discussion in 'Windows' started by jhicken, Jun 23, 2010.
  1. jhicken
    May 21, 2010
    25
    I might be completely blind as to where this setting is but can you change the 3CXPhone to display the time in 12hr format instead of 24 hr?
    Where is that setting???
    Thanks!
    ver. 4.0.12964.0
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Id like to change that myself. Any one know if you can? Thanks
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,405
    81
    The 3CX Phone displays Windows / System's time.
    If you change the time format of Windows, the time in the VoIP Phone should change accordingly.
    Start > Control Panel > Regional Settings
  4. carolinainnovative
    May 4, 2009
    369
    5
    Are you sure about that Leonidas? I have my regional settings set to the default north american settings (which is 12-hour AM/PM format) - and the soft phone still displays everything in 24-hour format.
    For me, I actually PREFER 24-hour format - but for most folks, that doesn't fly. Any thoughts?
  5. jhicken
    May 21, 2010
    25
    Same here.
    Everything is set North American and the Windows Clock shows 12hr format yet the softphone is 24hr.
    I know if I deploy the softphone to users this will be one of the first complaints.
  6. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,438
    61
    3CXPhone always displays time in 24-hr format, regardless computer's time diplaying format (for both of them, it's just a display mode). However, option to choose between 12-24-hr formats will be available in the next major release.
    Regards
    vali
