Change "From: User Part" field
Discussion in '3CX Phone System - General' started by poddyt, Apr 21, 2011.
  1. poddyt
    Apr 21, 2011
    is possible to change From field in Register request?
    I tried change "From: User Part" in "Outbound Parameters" in "VOIP Providers" configuration, but with no effect. 3CX still sends it unchanged.
  2. dbaird
    Apr 20, 2011
    Hi there, are you trying to change your outbound caller ID? I accomplished this on our system by setting the "From:User Part" variable to "Custom Field" and leaving the Custom Value empty. This causes our CID to appear on external phones as "Unknown". We are using NexVortex, so it may be different for another VoIP provider.
    These settings can be found on the "Edit VoIP Provider" screen, in the Outbound Parameters tab. After changing to the custom value, be sure to click the Add/Update button, then the Apply button. Otherwise, the settings will not save.
  3. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Depending on your locale, the VOIP provider may not allow changing the CID or have restrictions to phone numbers for you SIP trunk/DIDs.
