Change host name after install
Discussion in '3CX Phone System - General' started by bridgemanusa, Mar 4, 2010.
  1. bridgemanusa
    Mar 4, 2010
    7
    Hi All:
    I recently installed 3cx on a WinXP machine and found out after the install that my DNS server does not like host names with numbers in them. The domain I configured in the setup wizard was 3cx.mydomain.com and I need to somehow change it (to maybe threecx.mydomain.com) on the system but cannot (for the life of me) find a setting to change. Is this even possible?
    Any help is GREATLY appreciated.
    Thanks!
    Eric B
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You can change your SIP Domain by:
    1. Login to the 3CX Management Console.
    2. Go to Settings > Advanced.
    3. You will see a field called local SIP Domain - Change this accordingly.
    Most people put the machines private IP address and get away with it that way.
    Thanks,
    Mark Flores Martin
    3CX Support
  3. bridgemanusa
    Mar 4, 2010
    7
    wow.. I cannot believe I missed that. Thanks for the reply. That did it.
