change http port after install
Discussion in '3CX Phone System - General' started by voglsafe, Sep 19, 2016.
  1. voglsafe
    Sep 25, 2014
    9
    is it possible to change the http port from 5000 to 80 after installation?
    I've upgraded to V15 and obvious I've selected 5000. Https is correct set to 443.
    If not, what would be the best way to correct this?
    thanks
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,811
    564
    Hello there,
    I am afraid that your best option is to perform a full backup, un-install (restart your machine)and re-install by restoring your backup and selecting the ports you want when prompted in the installer.
  3. voglsafe
    Sep 25, 2014
    9
    thank you YiannisH.
    hmm.. that's bad. I might be change the configuration in the templates. I don't want to risk a breakedown after reinstall the system.
