Change HTTPS port after installation?
Discussion in '3CX Phone System - General' started by robxbl69, Apr 7, 2015.
  1. robxbl69
    Jun 8, 2013
    24
    When I upgraded from 12.0 to 12.5 I kept with 5000/5001, but now I'm using WebRTC I'd like to change 5001 to 443.
    I enabled the Abyss console and change it to 443 and whilst the management console works fine on 443, WebRTC is still expecting to be on 5001.
    Where do I need to change the port number in 3CX?
    Thanks, Rob.
  2. robxbl69
    Jun 8, 2013
    24
    In the end I resorted to a backup and restore and chose 443 during install. Left http on 5000.
    Only one issue was that even through I chose to backup SSL certificate(s), it didn't back up the CA signed certificate I'd added to Abyss for WebRTC, so I had to reinstall manually afterwards.
