Change in Outbound rules v12 SP4 international calls
Discussion in '3CX Phone System - General' started by techmikeny, Mar 17, 2014.
  1. techmikeny
    May 25, 2010
    20
    After upgrading to V12 sp4, it seems our outbound rules were changed.
    The rule for regular national calls didn't work and received a response "Called number does not exist"
    I recreated the rule with the following parameters:
    Calls to Numbers with a length of: 10
    Calls from extension group: ALL
    Route 1 SIPProvider Strip digits 0 Prepend 1
    Route 2 SIPProvider Strip digits 0 Prepend 1
    Route 3 SIPProvider Strip digits 0 Prepend 1
    The rule for international calls is as follows
    Call to numbers starting with prefix 011
    Route 1 SIPProvider Strip digits 3 Prepend 011
    Route 2 SIPProvider Strip digits 3 Prepend 011
    Route 3 SIPProvider Strip digits 3 Prepend 011
    The server event log shows the following (XX is the IP of our SIP Provider.)
    Call or Registration to 01131235519411@(Ln.10006@SIPProvider) has failed. [ V4 XX.XX.XX.XX:5060 UDP target domain=unspecified mFlowKey=816 ] replied: 404 User Not Found; from IP:XX.XX.XX.XX:5060
    Server Activity Log
    17-Mar-2014 13:51:39.163 Leg L:149.5[EndCall] is terminated: Cause: BYE from PBX
    17-Mar-2014 13:51:39.162 [CM503008]: Call(C:149): Call is terminated
    17-Mar-2014 13:51:39.162 Leg L:149.1[Extn] is terminated: Cause: BYE from 192.168.1.42:5060
    17-Mar-2014 13:51:33.929 [CM503007]: Call(C:149): EndCall:EndCall has joined, contact <sip:EndCall@127.0.0.1:40600>
    17-Mar-2014 13:51:33.928 [CM503007]: Call(C:149): Extn:102 has joined, contact <sip:102@192.168.1.42:5060>
    17-Mar-2014 13:51:33.925 L:149.5[EndCall] has joined to L:149.1[Extn]
    17-Mar-2014 13:51:33.776 [CM503025]: Call(C:149): Calling T:EndCall:EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=b86bafd7ab0d1048] for L:149.1[Extn]
    17-Mar-2014 13:51:33.722 L:149.1[Extn] failed to reach Line:10006>>01131235519411, reason Not Found
    17-Mar-2014 13:51:33.721 Leg L:149.4[Line:10006>>01131235519411] is terminated: Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.721 Call to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060] from L:149.1[Extn] failed, cause: Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.720 [CM503003]: Call(C:149): Call to <sip:01131235519411@termination2.sotelips.net:5060> has failed; Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.570 Leg L:149.3[Line:10006>>01131235519411] is terminated: Cause: 404 User Not Found/INVITE from 4.53.160.135:5060
    17-Mar-2014 13:51:33.570 [CM503025]: Call(C:149): Calling T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060] for L:149.1[Extn]
    17-Mar-2014 13:51:33.564 Call to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060] from L:149.1[Extn] failed, cause: Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.563 [CM503003]: Call(C:149): Call to <sip:01131235519411@termination2.sotelips.net:5060> has failed; Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.413 Leg L:149.2[Line:10006>>01131235519411] is terminated: Cause: 404 User Not Found/INVITE from 4.53.160.135:5060
    17-Mar-2014 13:51:33.413 [CM503025]: Call(C:149): Calling T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060] for L:149.1[Extn]
    17-Mar-2014 13:51:33.406 Call to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060] from L:149.1[Extn] failed, cause: Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.405 [CM503003]: Call(C:149): Call to <sip:01131235519411@termination2.sotelips.net:5060> has failed; Cause: 404 User Not Found/INVITE from XX.XX.XX.XX:5060
    17-Mar-2014 13:51:33.222 [CM503025]: Call(C:149): Calling T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060] for L:149.1[Extn]
    17-Mar-2014 13:51:33.172 [CM503027]: Call(C:149): From: Extn:102 ("Michael Epp" <sip:102@192.168.1.29:5060>) to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060]
    17-Mar-2014 13:51:33.172 [CM503004]: Call(C:149): Route 3: from L:149.1[Extn] to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060]
    17-Mar-2014 13:51:33.172 Line limit check: Current # of calls for line Lc:10006(@SIPProvider[<sip:1##########@termination2.sotelips.net:5060>]) is 0; limit is 4
    17-Mar-2014 13:51:33.172 [CM503004]: Call(C:149): Route 2: from L:149.1[Extn] to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060]
    17-Mar-2014 13:51:33.172 [CM503004]: Call(C:149): Route 1: from L:149.1[Extn] to T:Line:10006>>01131235519411@[Dev:sip:1##########@termination2.sotelips.net:5060]
    17-Mar-2014 13:51:33.172 Call(C:149): Call from Extn:102 to 01131235519411 matches outbound rule 'International'
    17-Mar-2014 13:51:33.170 [CM503001]: Call(C:149): Incoming call from Extn:102 to <sip:01131235519411@192.168.1.29:5060>
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    It looks like the rules are responding properly - but the provider doesn't recognize you.
