Solved change IP address
Discussion in '3CX Phone System - General' started by next2, Sep 19, 2017.
Tags:
  1. next2
    Apr 19, 2009
    39
    We'd like to pre-configure a debian install (from ISO downloaded on 3cx website) in our lab, and finish install at a customer site.
    Is there any way to change the LAN and GW IP addresses once the ipbx has been installed ?
    I can't find this anywhere on the web interface on an existing install. Maybe there are some linux commands we can send ?
    Thank you !
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @next2,
    Unfortunately you can 't change the internal IP address once the PBX is installed. What you can do is to install PBX at your customer 's site (the installation takes only 5 minutes) or if you insist for your own reasons to pre-install it at your premise, then you can do that by installing it behind a networking device (router, switch) with an IP same as the IP range of your customers network. Another option is to install it on the cloud but other issues will arise.
    Thank you
    #2 IoannisM_3CX, Sep 19, 2017
  3. next2
    Apr 19, 2009
    39
    OK. Thank you for the answer !
