Change mode for 3CX Phone
Discussion in '3CX Phone System - General' started by ice, May 6, 2013.
  1. ice
    ice New Member
    Jun 11, 2008
    108
    How to change CTI mode to SIP Phone mode for this softphone?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,968
    181
    I do not think that is ready just yet...
    head over to the blog comments http://www.3cx.com/blog/releases/3cx-phone-system-12-alpha/#comments for some answers...
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You can find 3cx inbuilt softphone option under the management console--->estenstions---> 3cx phone--->default phone to use. However I dont believe the feature is ready as of yet.
  4. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi, yes that is correct. Please let me know if you have any further inquiries
  5. matictec
    matictec New Member
    Mar 31, 2008
    188
    You have to configure the 3CX Phone settings in the extension settings to SIP Mode and than you have to resend the welcome mail again for this extension. Delete the account in the 3CX Phone and drag the new config file to the phone. You have to save the config file from the welcome mail to your local drive first.
  6. craigreilly
    Feb 1, 2012
    2,968
    181
    So I send the welcome email - we use Socketlabs for the Phone server.
    The email is received.
    In outlook 2013 this is the file:
    Code:
    <?xml version="1.0" encoding="UTF-8"?>
    -<tconfig> <Extension>11</Extension> <EXTGUID>43af4358-da75-4d8c-944d-c6dea91d24f7</EXTGUID> <GCMSENDERID/> <AccountName>Craig v12</AccountName> <outboundCID/> <AuthID>11</AuthID> <AuthPass>xxx</AuthPass> <VMAILPIN>xxxx</VMAILPIN> <PBXLocalAddr>10.0.0.13</PBXLocalAddr> <PBXPublicAddr/> <PBXSipPort>5060</PBXSipPort> <UseStun/> <StunServer/> <StunServerPort>3478</StunServerPort> <StunServer1/> <StunServerPort1>3478</StunServerPort1> <StunServer2/> <StunServerPort2>3478</StunServerPort2> <Codecs/> <Voicemail>99</Voicemail> <SIPTransport/> <RTPTransport/> <DtmfRFC2833/> <DtmfInband/> <DtmfSipinfo/> <DtmfPayload/> <RegistrationTime/> <UseTunnel>0</UseTunnel> <TunnelPort>5090</TunnelPort> <TunnelPass>xxxx</TunnelPass> <UseProxy/> <ProxyAddr/> <ProvLink>http://10.0.0.13:5000/provisioning/erh9v2fvox/TcxProvFiles/3cxProv_130502120057_11.xml</ProvLink> <MyPhoneServerLocalAddr>http://10.0.0.13:5000/MyPhone/MPWebService.asmx</MyPhoneServerLocalAddr> <MyPhoneServerPublicAddr>http://xxx.xxx.xxx.xxx:5000/MyPhone/MPWebService.asmx</MyPhoneServerPublicAddr> <UseCTI>true</UseCTI> <StartUpScreen>1</StartUpScreen> <lamps/> </tconfig>
    In Windows 8 Webmail using IE, I get an empty file when I save the file. Thus dragging it to 3cxPhone does nothing. So, I goto the Outlook machine, save the config file to a thumbdrive. Move it to the Win 8 machine. and drag the file over. It sets up the softphone. But when I goto make a call, the Yealink instead does the "MakeCall" thing instead of just ringing the party I am calling.
  7. craigreilly
    Feb 1, 2012
    2,968
    181
    I did get CTI working. The phone was new in the box and may have been on an older firmware when I first started htis project. I uninstalled MyPhone, cleaned the registry, and then reinstalled. Dropped the config file.
    The first time I tried to make a call the phone asked if I wanted to allow remote control.
    I said yes. Then had to hang up and then all was good.
