Change multi Varibles By One Component
Discussion in 'Call Flow Designer' started by KTT, Nov 4, 2017.
Tags:
  1. KTT
    KTT
    Oct 22, 2017
    9
    Dear Sir,
    I have multi loops in my design, now I'm using many of Assign Variable components to change loops variables.
    So can you please help me to know how to change many variables using one Assign Variable component to change multi variables.
    Thank you in advance.
    BR,
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,233
    95
    Hi @KTT,
    You can't do that. The "Assign a Variable" component only allows setting a single variable.
    If you're using project variables (instead of callflow variables), then you can create a custom component, assign variables there, and from your callflow you just call your custom component.
    Kind regards.
