change my timezone
Discussion in '3CX Phone System - General' started by Yosi, Aug 23, 2017.
Tags:
  1. Yosi
    Aug 23, 2017
    how can i change my timezone on 3cx cloud?
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    905
    137
    Hi Yosi,
    By 3CX Cloud I am going to assume you mean a 3CX system hosted in the cloud although please specify.
    In 3CX go to >> Settings >> Timezone, Office hours & Holidays >> Global Time Zone.
    Also double check your NTP server settings,by default they are on pool.ntp.org:
    Management Console >> Settings >> Parameters >> search for TIME_NTP_SERVER . On the value you will see the domain pool.ntp.org.
  3. AlexDBarrett
    Jan 25, 2011
    71
    9
    Is your cloud server showing the correct time for your region?
