Change number the softphone dials for VM
Discussion in 'Windows' started by filemakers, May 21, 2011.
  1. filemakers
    May 20, 2011
    I was prompted to enter the mailbox number for voicemail on the 3cx softphone client, I stupidly entered the phone numer of the extension, and now I am unable to change it to the correct VM extension number, I have tried editing the line PBXVoicemail=101 in the local 3CXVoipPhone.ini on my pc, to the correct VM number, however everytime I restart the client it resets back to the 101 that I put in originally.
    The Server has been changed to a number away from 999 as I am in the uk, however this doesnt seem to carry down.
    I am guessing it has stored it on the server somewhere, but I have no idea where to start looking, I am a newbee to 3cx and voip systems in general, however a IT technician, I am guessing there is some kind of provisioning file per extension stored? Can anyone tell me how to correct my faux pas.
    Thanks in advance.
  2. filemakers
    May 20, 2011
    Ok... Sorry, I have managed to work out how to do it, the fix was as follows, close the softphone, edit the file, change the line entry listed previously and then save it, then make the file read only, reopen the client and then make the file not read only again, after reopening the phone again after the file was writable has seemed to update the softphone permanently.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    Looks far too complicated. Open account's Advanced Settings dialog, then try to change there "PBX voicemail" parameter and see if is working.
    Regards
    vali
