Change of Port
Discussion in '3CX Phone System - General' started by whitewhite, Sep 7, 2011.
  1. whitewhite
    Jul 11, 2011
    20
    I am wondering if we can change the port for 3CX softphone: TCP 5000-5001, as I need that ports forward to another server on the other program.
    White
  2. willow
    willow Member
    Mar 1, 2011
    471
    The PBX uses port 5000 for the web management. This is not changable.
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hello White,
    There is information here regarding port changes: http://www.3cx.com/forums/important-note-3cx-v10-web-port-changed-to-20017.html
    It isn't recommended but if you must have it you can configure it here. Do remember to take note with this and if support issues ever come up you will also need to remember to tell support this first off.
    Thanks,
    Nate
  4. willow
    willow Member
    Mar 1, 2011
    471
    this is good to know.
  5. willow
    willow Member
    Mar 1, 2011
    471
    though it seems that it would need to be redone after every reinstallation or major upgrade.
  6. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Exactly, it won't stay in the settings I believe on uninstall and reinstall. I haven't tried it because for me port 5000 is fine.
    Thanks,
    Nate
