Change on Hold Music
Discussion in 'Windows' started by Tularis, Apr 12, 2010.
  1. Tularis
    Apr 12, 2010
    16
    Is there a way to easily change the on hold music. I have been up and down the entire menu and cant seem to find anything. :)
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,582
    115
    You can do this by going to the Management Interface > Settings > General > On Hold Music
