Solved Change order of numbers on caller-id display
Discussion in '3CX Phone System - General' started by David Tutwiler, Mar 15, 2017.
  1. David Tutwiler
    Jan 13, 2017
    12
    Currently, our system is setup to display the caller name on the caller id. However, when the name isn't found in any phone book, 3CX displays the number that is being called (the number of the phone receiving the call) first and then scrolls to the number that is calling. I have had several users complain that they didn't know who was calling in, until the call had ended. Can I change this so the calling in number displays first?
    We're using an on-prem 3CX and SNOM D715 handsets.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi David,
    To change the order of numbers on display caller-id you can go to Management Console => Contacts => Options => and choose the Append Name.
    Please let us know if it works for you.
  3. David Tutwiler
    Jan 13, 2017
    12
    This was the opposite of what I needed, but it got me right where I needed to be. Thank you.
