Change Phone Template without Reprovisioning a phone
Discussion in 'Ideas' started by Daniel Lent, Aug 26, 2017.
Change Phone Template without Reprovisioning a phone 5 5 6votes
5/5, 6 votes
  1. Daniel Lent
    Dec 15, 2016
    16
    9
    Another annoyance that I've come across while doing this large install is that if I have to make a custom template to use for whatever reason, I have to manually remove and add the phone on the extension to be able to select the new template file. Ok if you only have to do this one or twice, maddening when you have to do it 20+ times.
