change recording quality (v15)
Discussion in '3CX Phone System - General' started by easydone, Dec 8, 2016.
  1. easydone
    Nov 22, 2016
    8
    Is there a way to change the quality of the recordings (a parameter for which codec to use) ?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    No i am afraid there is not
