Change Ring Tone
Discussion in 'Windows' started by rscl.mumbai, Dec 8, 2010.
  1. rscl.mumbai
    Jul 22, 2010
    8
    Is there any way to change the default ring tone ?
    Could not find any direct option.
    Thx in advance.
    Sanjay
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, i assume you mean the 3CX Soft Phone, if so then i don't think there is a way of doing this.
    Other then using the Windows Sounds via Start Menu Control Panel
  3. rscl.mumbai
    Jul 22, 2010
    8
    I was able to change the ring tone.
    Sanjay
