Change ringtone in 3CX Windows Phone v12
Discussion in 'Windows' started by kgrundstein, Jan 16, 2014.
  1. kgrundstein
    Aug 5, 2013
    Is there a way to change the ringtone in v12 3CX Phone for Windows. Replacing the ringtone.wav seems not to be working.
    Thanks,
    Klaus
  2. norekhov
    3CX Support
    Jan 31, 2014
    53
    You can replace ringtone.wav in the "Sounds" folder and it will work.
    Please, try again or describe what you were doing.
    There's no other place where 3CX Phone can take it's ringtone but Sounds/ringtone.wav
    Regards, Nikolai Orekhov
    Software developer @ 3CX
  3. RussRiopelle
    Feb 4, 2014
    38
    I can find the file. If I replace it does it need exactly the same name "ringtone.wav"??
  4. norekhov
    3CX Support
    Jan 31, 2014
    53
    Yes, It should be exactly the same name and folder.
    To be sure it should be "wav" file and not "mp3" file renamed to ".wav".
    But you can try mp3 as well, it might work also.
  5. RussRiopelle
    Feb 4, 2014
    38
    I have tried to replace the ringtone.wav file with another of the same name and the phone does not ring.
    I have closed and opened 3CX a few time but to no avail.
    If I put the original ringtone.wav file back the ring comes back.....
    Is there something else I have to do to make this work??
    thanks..
  6. norekhov
    3CX Support
    Jan 31, 2014
    53
    PJSIP states that file should be "16bit PCM mono WAVE, 8KHz".
    You can check the file format in Winamp for example.
    Please, find a suitable converter and convert your file to that format.
