Change Ringtones 3CX Phone
Discussion in 'Ideas' started by relesys, May 1, 2017.
  1. relesys
    Dec 10, 2013
    Is it possible to simply change the ringtones in the 3CX Phone (client)? (Without .wav file exchange)
  2. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    no
    I think, if you only want to change it... changing the .wav is a sufficient solution.
