Change status of other extensions from 3CX Client
Discussion in 'Ideas' started by kieferschild, Jan 4, 2018.
Change status of other extensions from 3CX Client 5 5 4votes
5/5, 4 votes
  1. kieferschild
    Jul 1, 2016
    37
    6
    It would be handy to be able to change statuses of other extensions from the 3CX Client without having to log in to the management console or dial voicemail.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @kieferschild
    This is already possible through the web client as you can change the status of an extension given you have the appropriate right enabled under your extension rights. You will need to enable the receptionist right to be able to perform this actions.
  3. kieferschild
    Jul 1, 2016
    37
    6
    that's great but not ideal for the customer.
    They already have the 3CX Client along side the receptionist view. The last thing they want is a 3rd window to be able to do something easy like change a status.
    My customer doesnt want to have to log in to webclient each time they leave the office.
    If they had incoming calls to a dummy extension and the destination depended on status, logging in each time isnt convenient. Whereas, being able to do it from the 3CX Client is.
    Joe Bobbitt likes this.
  4. Joe Bobbitt
    Jan 25, 2018
    It's frustrating for managers who can log people in and out of queues from the windows client but can't update status the same way. Seems like an oversight.
  5. info@matic-tec.de
    Mar 25, 2008
    19
    7
